JON BUCKMAN
elf file does not follow program execution on cw for mpcxxx v8
Discussion created by JON BUCKMAN on Oct 27, 2006
Latest reply on Oct 30, 2006 by Nouchi
Why does the source window pointer jump all over (does not follow program execution) while debugging in cw mpc v8. This also happens in the pemicro debugger using the same cw generated elf. However, the disassembly execution is correct. Thanks.
