Ted Wood
DMA, FEC and D-cache coherency
Discussion created by Ted Wood on Oct 19, 2006
Latest reply on Feb 2, 2010 by TomE
We are using the MCF5475 with the Freescale supplied example code for using the FEC and DMA. With data cache disabled it works fine. When the cache is enabled it fails (not surprisingly) because cache coherency is not maintained during DMA.
I can see two possible solutions to this problem.
1. Invalidate the cache after DMA to memory and flush it after DMA reads.
2. Place the buffer memory in non-cached memory.
I can see how to do 2. I can't work out from looking at the Freescale code (fec.c fecbd.c) where to flush and invalidate the data cache. Somebody must have been here before surely?
All suggestions welcome.
Cheers
TW
