I am using Codewarrior 7.3 -- 56F8357. I have be built and been debugging a project using project expert for months. I need to make another project that is a variation of the first. I copied full project to new directory, created a new project name and project expert, imported the beans from old project, used old project cpu template added files from old project, renamed "main" file to new project name -- all should be good right? I keep getting segment overflow .xdata. Does anyone have a clue? It won;t build a map file with this error. I have made no code changes so it must be in the configuration. This is annoying. I am sure its a configuration hidden in the settings area -- but how do I find it. Is there an easier way to "copy" a project? Thanks. M.E.
Message Edited by CrasyCat on 2007-04-13 01:43 PM
