I'm having the exact same problem. Technological Arts sells a BDM that runs D-Bug12. The original modules I purchased contained D-Bug12 4.0.0B18. This specific version of D-Bug worked great and I had no problems running it with the MC9S12C32 chip. Later versions of the module were shipped with 4.0.0B32. I've never had any success at getting these modules to run. I received the same error messages (S Rec out of range).
Does anyone know where to download D-Bug12 4.0.0B18? I, for one, would like to get a copy so I can get some of my newer debug modules running correctly.
KH@SRNL, I haven't used D-Bug12, but like Imajeff noted, are your Srecords in linear (physical) format? That would mean all your C32 S records must be between F8000 and FFFFF.
Are you using Codewarrior? If yes, then you may find right *.phy (S records) file in your projects /bin folder.
Message Edited by imajeff on 2006-09-19 05:02 PM
