William Whyte
Data Compress functionality in Flash
Discussion created by William Whyte on Sep 6, 2006
Latest reply on Sep 17, 2006 by William Whyte
I am useing a 9S12E256 and there is a flash command for "Data Compress" to check the data integrity.
Does anyone know the algorthim that this uses, as I would like to calculate the expected signature from an srecord and then add that in to the srecord. This way I can use it to check that the code was loaded correctly.
