gcvt and stack overflow
TTA
When i am using gcvt() function in my application, it is causing a stack overflow. Can you please let me know if there are any compiler/linker settings that need to be done to avoid this problem.
Kindly do let me know.
TTA
CrasyCat
Specialist III
Hello
Well you will have to change something in your application.
  - You may define a bigger stack in your linker configuration file
  - I would also suggest you to check your application and make sure you do not have
    big arrays or data structure local variables.
  - Also avoid when possible to pass structure as parameters to a function. Whenever possible
    pass a pointer to the structure.
    This is using less memory on the stack.
CrasyCat
