HIWAVE virtual SCI
HIWAVE virtual SCI
jackzhou
The MCU is MC9S08GB60,and the Codewarrior Version is 5.7.
I want to debuger sci0 use the HIWAVE simulator.
I printf a string throught the sci0,i can get the information in SCDO
window.
But i can get nothing in the Component Terminal.
How can i correctly redirect the sci0 to the Component Terminal in the simulator?
Best Regards!
Thanks!!
jack
CrasyCat
Specialist III
Hello
Unfortunately this is not possible with the HC08 Full Chip Simulator.
This is based on a technology, where simulation is not extendible.
This is possible on HC12 simulator only.
CrasyCat
CrasyCat
Specialist III
Hello
As far as I know this is not working in the HC08 tools today.
I have forwarded a request for extension around that to our planning people.
For the moment if you want to look at what is written to the SCI serial port, you have to open a Hyperterminal session and connect it to your Host serial port you have connected to SCI0.
CrasyCat
jackzhou
Thank you for your reply.
In HIWAVE.hlp i found the below:
    Only some specific simulator target components currently have a Sci0 object. For all other simulator  target components, the Terminal component does not work unless a user defined Sci0 object with the specified register name is loaded.
Metrowerks Europe - August 2002
Becasue i want to do software test,so i want to do it in simulator,maybe can i develop the  Sci0 object myself?
Or maybe you can tell me how long will this be available in HC08?
Thank you very much!
jack
CrasyCat
Specialist III
Hello
CrasyCat
