TIM LAPSLEY
Project window, How to configure Data column to show RAM usage?
Discussion created by TIM LAPSLEY on Aug 17, 2006
Latest reply on Aug 22, 2006 by CrasyCat
I'm using CW 6.3 for CF. In the project windown there is File, Code, Data columns. After compiling the Data column shows the usage for (I'm assuming) rodata, data and bss. My rodata is in the flash and I would like to have an easy way to see the RAM usage (data + bss) for each of the files (other than go through the map file everytime), is this possible at all to configure this Data column to show what I need?
