This is the first time am using CW tool.I have an application in which I need to open the command window of CW using perl scripts. The following snippet launches CW debugger .
use Win32:LE;
$CW=Win32:LE->new("CodeWarrior.CodeWarriorApp");
$textDocument = $CW->OpenTextDocument('D:\temp.txt', 1);
print ("Press any key to continue ... ");
$_ = <STDIN>;
Could someone help me to launch the command window of CW IDE using perl scripts.
Thanks .
