Scott Shaw
File Not found error
Discussion created by Scott Shaw on Aug 13, 2006
Latest reply on Aug 14, 2006 by Scott Shaw
I am taking code already compiled by a contractor and need to use Code Warrior only to access and burn the code to a chip.  When I try to compile the existing code I receive hundreds of C5200 errors indicating that the files cannot be found.  However, clicking on any of these file names shows that the file path leads to the proper sub-folders where all my code is stored.  "Help" advises me toSpecify the correct path and name of your source file!
But I cannot figure out where to do that either.   I have a call in to Tech support, but really need to get going on this project!
Any help please!
