Sorry I do not understand the question here.
Do you mean you want to prevent CodeWarrior from opening the last project it has opened?
What is exactly the problem can you be more explicit and explain what you are doing and what you are seeing on the screen.
CrasyCat
I'm sorry but I haven't reproduced the problem. I have:
- created a new project with PE
- selected the 'Suspend Processor Expert for ..' menu command
- Closed CodeWarrior, re-opened the project and checked the 'Don't ask again' checkbox in the PE dialog.
and the dialog haven't apperaed anymore after next opening...
I recommend you to create a new project without Processor Expert and insert the sources from your current project there. This should definitely help.
best regards
Petr Hradsky
