Antonio Quevedo
Rechargable Battery
Discussion created by Antonio Quevedo on Jun 24, 2012
The Quick Start Guide for Kwikstik, in its "Additional Features" section, mentions that the board has a Li-Mg rechargable battery, and that both USB connectors can charge it. i have tried to keep my board plugged to my computer so it would charge battery. However it seems that the battery does not charge at all, because I can only make the board work when plugged to my USB port. I have tried to charge battery using both J-Link and K40 USB connectors, and with the switch in bioth ON and OFF positions, with no success.
Is this battery working for anyone? Is there any trick I should do so the battery can be charged?
Thanks in advance
