Oren Lavi
Copy function to stack
Discussion created by Oren Lavi on Jul 20, 2006
Latest reply on Jul 20, 2006 by Marc Vincent
Hello
Does someone has an example code how to load function to stack and run it there (i need it to program/erase flash)?
Do i need to run from the memory only the command to the flash or more (in the program command flow)?
