Jack Haller
TWR-K60N512 keil 4.5 IDE PEmicro OSJTAG does not run reall time per Freescal Kinetis Lab.pdf
Discussion created by Jack Haller on Mar 29, 2012
Latest reply on Mar 29, 2012 by Abhinav Singh
I did not see a similar post on this in the forum so here we go-
I was working thru the "Freescale Kinetis lab.pdf" Using TWR-K60N512 and flashing/debugging thru PE MICRO OSJTAG.
Using Keil 4.5.0 I ran the c:\keil\Boards\Freescale\Blinky program. It downloads and runs fine. However, during debugging realtime updating of certain variables (ie 'num' variable, defined statically defined from the symbol window with View/Periodic Window Update checked) does not really update real time.
Does anyone know the cause of this discrepancy? I was suspecting OSJTAG is not capable of realtime updating? I have a Segger J-link in hand and a 100mil->50mil cortex debug adapter on order so perhaps that will take care of this?
Jack
