Message Edited by RocK on 2006-07-17 10:43 AM
What data type is OutputBuffer declared as? If it is a char then there would be no ninth bit to set.
SCC3_T8 = (OutBuffer[OutIndxR] >> 8) & 1; /* Set the ninth bit */
Otherwise, this should work - provided that the SCI has been configured for 9 bit data.
rhinoceroshead wrote:What data type is OutputBuffer declared as? If it is a char then there would be no ninth bit to set.
