How to trace interrupts in Code Warrior for HC08  v5.1
tupham
Dear all,
I am debugging Code Warrior 5.0 for HC08 program. If anybody know how to trace interrupt functions in Code Warrior, please help me.
Thanks so much.
Tu Pham.
Bud
Locate your interrupt jump vector table.  I don't know how you have set yours up, however you might want to look into mcu_init.c.. you can see from the jump table, the names of the different interrupt routines and you can set a breakpoint in the routine you are looking for.
An easier way might be to make a file called isr.c and include your interrupt jump table there as well as all the interrupt service routines you want.
Bud
