Anyone know why this isn't working?
FCDIV_DIV = 19; // divisor for FLASH clock divider (decimal)
In the MC9S08QG8.h header file, FCDIV_DIV is defined as the merged bits (_FCDIV.MergedBits.grpDIV) of the FCDIV register. I realize that the foolproof method of setting these bits accordingly would be simply:
FCDIV = 0x13; // FLASH clock initialization to 200kHz for 4MHz bus clock
But it's more readable the other way, since that's how the datasheet lists the DIV bits.
I know that using the merged bits method works, as I've used it successfully for the timer register:
TPMSC_CLKSx = 0b01; // Select BUS clock
Any ideas why the QG8 doesn't like this method in the FCDIV register?
