Perini Arcangelo
USB TAP problem....
Discussion created by Perini Arcangelo on Jun 28, 2006
Latest reply on Dec 2, 2015 by Pascal Irrle
  I was work correctly with USB TAP until today.
NOW, when I start debug, on screen appear an error window with this message:
" CCSProtocolPlugin: CCS: Library not found "
Why?
What can I do?
some note:
-> When I connect USB TAB to computer a green led [TX/RX] flash
-> On PC, in: Control panel -> peripheral managment -> Hardware    I can see "CodeWarrior USB TAP"
-> If I disconnect USB cable the error message change:
" CCSProtocolPlugin: CCS: USB open failure "
-> I have try to update firmware in USB TAP but nothing change...
