bigtuna bigtuna
D4D flow numbers
Discussion created by bigtuna bigtuna on Sep 28, 2011
Latest reply on Nov 26, 2011 by metin genc
Hallo, i'm working on TWR-LCD and developing with CW6.3 using D4D libraries, in C code.
I need to show a simple label with a long number as this:
SPEED= 123.34
In the D4D GUI use guide, and looking in some demo i have found this API:
#        D4D_SprintDecU8(Byte val, char *pText, char fill);
and other similar.
In my code i have wrote:
Byte tmp;
long value;
value =123.34;
tmp = D4D_SprintDecS32((sLWord)value, &speedy[0], (char) 0);    speedy[tmp] = 0;
speedy was declared before.
After this i can read only "123", so i guess that i can't show long numbers, but just integer.
Is that real? How Can I print flow numbers on screen?
Thank you very much.
