Hello
All supported version control plug ins are enumerated at following URL:
http://www.freescale.com/webapp/sps/site/overview.jsp?nodeId=01272600613367
We do not have support for SVN.
CrasyCat
You say you dont support SVN. That was in 2006 - do you now support it? Thanks
Hey, Freescale supports SVN in CW10 now, though they may not be aware of that Since CW10 is now eclipse based, you can install subclipse plugin into it from subversion.tigris.org or optionally subversive from eclipse.org.
That is not easy though. CW10 has a complex configuration, so simple Eclipse's update process does not work as expected. You may need to unzip the plugins manually into eclipse subfolder of the CW10 directory.
Still, CW7.2 does not support svn yet.
Im having the same is and was interested to know if you had created a plug-in for svn or had managed to get round the problem in some other way?
I have no idea how to write my own pug-in so any pointers you can give would be much appreciated.
Dave
