Hello
I assume you are using CodeWarrior for HC08 V5.x.
In fact the compiler notifies you that you have passed a constant pointer to character to a function expecting a pointer to character.
This message is a warning per default as required by ANSI C standard.
You can disable this warning activating the option -Ec.
I hope this helps.
CrasyCat
