marcelo biagetti
Interfacing an mmc/sd memory card to hc08
Discussion created by marcelo biagetti on Jun 8, 2006
Latest reply on Aug 3, 2006 by Kirit Basu
 Does anyone has an application note or any example in which an hc08ap32  spi port is connected to an mmc/sd memory card.
Im trying but we have some troubles , the system works well in debug mode, but not alone.The spi signals are ok, and micro works fine.
Also when we connect the micro with the card together it does not work, (the supply pwer goes down)
but if you connect first the micro and then insert the card it works,
Any idea will be welcome.
thanks a lot.
