I know this is old, but I see no resolution and I was having this problem so I figured I would throw my solution into it.
In the linker file, I was using
. = ALIGN(2)
but I really wanted to use ALIGNALL but I mistakenly put in
.= ALIGNALL(2)
when it should be just
ALIGNALL(2)
That made the error go away.
Hello
Please submit a service request through the web interface at following URL:
http://www.freescale.com/webapp/sps/site/homepage.jsp?nodeId=054670
Attach a project reproducing the trouble to the request.
CrasyCat
Was there any resolution to this issue? We have seen this issue in our project on a particular workstation. A build on other workstations (same project files) does not yield this error. The "Errors & Warnings" window indicates a link error with the
message "Linker Error : Linker command file error at line 228 "move current location backward". The specified line number
is the last line of the LCF. We have attempted to close CW and delete the CW data directories - error still appears.
