Hello
Which version of CodeWarrior are you running?
To retrieve that information:
- Start the IDE
- Select "Help" -> "About Metrowerks CodeWarrior""
- Click on "Installed products"
- product currently installed are written on the top of the dialog.
Which debug connection are you using (simulator, Multilink, .....)?
Which component did you open to get Trace data?
CrasyCat
Hello
Trace component should be working with CW HC12 V4.5.
I would suggest you to submit a service request through our web page.
Please attach the installed plug in document and a project reproducing the trouble.
You can use the Pack and Go wizard to collect all info needed to forward a project. Use Help -> "Pack and Go" to start the Pack and Go wizard.
CrasyCat
Message Edited by elid on 2006-12-0610:37 AM
Message Edited by elid on 2006-12-0610:40 AM
