Fadi Bassil
sharing SCI port
Discussion created by Fadi Bassil on May 3, 2006
Latest reply on May 18, 2006 by bigmac
Hello all,
is a chip that i can youe to multiplex the SCI port between 2 connections. the idea is that i'm using the SCI port to communicate to an mc33290 chip and i need it also to communicate with the PC through RS232. i'm using the 9s12c32(44pin) that comes with the studen learning kit and it has only one SCI port.
Thank you all.
