Codewarrior 10.1 Special edition license
Discussion created by Guest on Mar 13, 2011
Latest reply on Apr 11, 2011 by Luis Casado
I had noticed that the special edition version will bring up a dialog that asks for a license file even though it is supposed to work without one.
I had been using the 30-day eval to get around this but just discovered that if I just close the dialog every time (it will re-appear after you close),  it will eventually go away and CW will compile.   The first time it took about 7 closes before the dialog to go away.  Everytime I compile I have to close the license dialog 3 times.
