Single precision and double precision on MPC555
sramilho
The initialization of global variables and calculation with global variables defined float and/or double don't work.
CrasyCat
Specialist III
Hello
Which version of CodeWarrior software are you using?
Did you create your project using a stationery?
Did you specify you want to use floating point arithmetic when you have created your project?
Which format did you specify for floating point arithmetic (software, hardware, ...)
Which library file did you ink to your application?
CrasyCat
