Brian Espenschied
CodeWarrior Visualization Tool Documentation
Discussion created by Brian Espenschied on Apr 30, 2006
Latest reply on Apr 17, 2009 by Pedro Vezzali
I am trying to use the Visualization tool in the True-time Simulator of Codewarrior for the HC08. I can not find any documentation on this tool that explains how to use it. The documentation I found is VERY limited and does not explain any specifics.
For ex. If you use a PushSwitch there are many options under the Kind of port. None of them are explained. I can not get the switch to actually toggle a port pin like a switch would do no matter what I have the settings set to.
The LED tool is easy to use and works fine.
Anyone ever use this tool and have any ideas?
This tool is found under the Component menu item of the simulator.
Thanks!
