Tarun Thomas Abraham
Codewarrior for Coldfire - RTOS support
Discussion created by Tarun Thomas Abraham on Apr 28, 2006
Latest reply on Apr 28, 2006 by Marc Paquette
I understand that the Codewarrior for Coldfire Standard Edition 6.2 , does not support RTOS level debugging.
But i assume that i will be able to debug my task code. So in the below code i should be able to debug Stat1, Stat2 etc.. Is my assumption correct?
Also, advantage of RTOS level debugging would be that i will be able to debug the RTOS code itself. Is that correct?
Kindly let me know.
Init()
  CreateTask(NewTask,Priority,"NewTaskName");
  Start(NewTask);
void NewTask()
  Stat1;
  Stat2;
