Jean-Frederic Gauvin
Window pro 7 and eclipse 10
Discussion created by Jean-Frederic Gauvin on Nov 12, 2010
Latest reply on Nov 23, 2010 by Robyn Weil
I just get started with the Tower system and I have first install code warior under windows virtual PC XP mode and that was no problem to run and create application for the dev kit.Then I moved to 64 bits and now I cannot connect to the target.
I have the following message
Can't connect. The Debugger can not connect to the P&E BDC interface or targetted hardware board. (ColdFire GDI Protocol Adapter)
Does anyone has encounter the same problem?
Jean-Frederic
