Frederic JAFFRY
flashing 5208 Evaluation board with CF Flasher
Discussion created by Frederic JAFFRY on Apr 20, 2006
Latest reply on Apr 21, 2006 by Frederic JAFFRY
Hello, I am a new user of this forum.
I use a 5208 Evaluation board and the USB multilink device for accessing the flash memory. The software associated with this BDM is CF Flasher 3.1.
I have some problem when I use CF Flasher: the board can not be accessed (an error message indicates that the microprocessor can not be forced in background mode). I have tried with another software (limited soft given by PE Micro, the BDM constructor) and it works.
Does CF Flasher need a special computer configuration or something else?
Thanks in advance
