Rob Dore
How to execute code from flash after reset?
Discussion created by Rob Dore on Apr 14, 2006
Latest reply on Apr 14, 2006 by Jeff Smith
Hello all,
I am trying to program some code that I have written in ICC12 onto a custom pcb with a P&E multilink BDM. The processor is a MC9S12DP512. I can load the code and step through the program with Noice. How do I make it so the code will execute after I remove the BDM and reset the board? I need the board to run without the BDM attached. Thanks for any help.
