Walter Muth
Using  J18 TGT_BDM
Discussion created by Walter Muth on Jan 28, 2010
Latest reply on Jan 29, 2010 by Walter Muth
Hi all,
we have a problem with the onboard OSBDM (JM60) on our TWR MCF52259 board. So we want to try for debugging and flashing the J18 connector with the P&E USB-ML-CF Multilink interface . Unfortunately there is nothing about using this 26 pin header in the documentation. I think the switching could be simply done by not using the OSBDM. So OUT_EN will not connect the signals to the MCU and we can use the external BDM (USB-ML-CF). Is this correct?
Walter
