Codewarrior For powerpc V8.5 for debugging mpc8540 bootrom.elf built by diab5.0 in tornodo IDE, the tornodo version is 2.2.1.
When following the instrument in "Debugging External ELF Files" in the chaper 6 of the Targeting_Embedded_Powerpc.pdf , it's seem not work, but I think the elf files is a common standard for debugging files.
My question is, if can the codewarrior for powerpc debugger import external built elf files for debugging?how to do it ? giving some examples is appreciated.
