sirlenzelot
MCF5234: Cannot Program last Sector of Am29DL163DT Flash on CustomBoard
Discussion created by sirlenzelot on Aug 31, 2012
Latest reply on Sep 10, 2012 by sirlenzelot
Hi All.
We have a Custom Board (Rev1) with the Am29DL163DT Flash and encounter the following problem:
We cannot program the last two Sectors of the Flash (Offset 0x1FC000 and 0x1FE000). Any other Sector can be programmed.
The board is designed using freescale's EVB-example.
When using the original 5235 EVB everything goes. (Flash here is Am29PL160CB)
Flashing a newer Custom Board (Rev 2) with the S29GL064 works fine.
Did someone encounter similar problems with Flashs or can give some hints.
Thanks in advance.
vy 73
Dirk
