CW10.2(Eclipse) S08DZ - No chance to invoke burner via automatically generated makefile
Question asked by Pawel Irzmanski on Aug 27, 2012
Latest reply on Aug 28, 2012 by Pawel Irzmanski
Hi all,
I am working on workspace with two projects: PrA and PrB, where PrB is a copy of PrA with different name.
PrA generates for me perfect HEX file, PrB doesn't (the same bbl files).
I found that automatically generated makefile of PrB differs only in this part:
PrA (automatically generated makefile):
# Add inputs and outputs from these tool invocations to the build variablesEXECUTABLES += \Project.abs \EXECUTABLES_QUOTED += \"Project.abs" \EXECUTABLES_OS_FORMAT += \Project.abs \BURNER_OUTPUT_OUTPUTS += \Project.abs.s19 \BURNER_OUTPUT_OUTPUTS_QUOTED += \"Project.abs.s19" \BURNER_OUTPUT_OUTPUTS_OS_FORMAT += \Project.abs.s19 \
 PrB (automatically generated makefile):
# Add inputs and outputs from these tool invocations to the build variables EXECUTABLES += \EXECUTABLES_QUOTED += \EXECUTABLES_OS_FORMAT += \BURNER_OUTPUT_OUTPUTS += \BURNER_OUTPUT_OUTPUTS_QUOTED += \BURNER_OUTPUT_OUTPUTS_OS_FORMAT += \
When I put missing strings into obove lines, and disable "auto makefile generation" option, it builds requested output file with success.
I cannot  find source in project configuration connected with this issue. Maybe I miss something in burner or linker options ?
Anyone had such problem ?
regards!
Paweł
