USBDM application compile guidance
Question asked by Mike Durller on Aug 15, 2012
Latest reply on Apr 3, 2013 by Nouchi
PGO,
Could you please provide more detailed build guidance for the USBDM applications package in Windows 7?
Specifically, I think it would be helpful to know what versions of the software packages you use are, and with what configuration options you compiled source package dependencies such as wxwidgets and xerces to make it all work. Personally, I tried using msys + mingw, apparently successfully, - but you may have done it differently?
Once egit is invoked from within eclipse I get many instances of "The currently displayed page contains invalid values " popup dialogues when C++ paths are clicked. Also, I am getting errors about -lusbdm-debug.4 missing from the linker, creating tons of java.lang.NullPointerExceptions. Do you have any hints or there some others steps involved to setting eclipse up right to build?
Thank you for your time.
