I am using CW10.2 for the Kinetis K60. I am not sure if the Indexer in my installation worked at all - currently it does not. So I searched through this forum and found the hint to uninstall it - especially if you have MQX installed, which I did.
So I uninstalled my CW10.2 and did not install MQX again. However I have still now Indexer functionality and choosing 'Rebuild' from the project menu did not change anything.
Does anyone have a suggestion?
Best Regards
Markus
Solved! Go to Solution.
Choose Windows > Preferences. The Preferences window appears. Expand the C/C++ item, and then click on Indexer to display how the IDE manages indexing of symbolic information. The key option you want to confirm is that the Enable Indexer option is checked.
---Tom
---Tom
