Dan Cheever
BDM Tracing XGATE in CodeWarrior HC12 V4.5
Discussion created by Dan Cheever on Mar 18, 2006
Latest reply on Apr 4, 2006 by CrasyCat
Is there a way to get the XGATE trace to act like the S12X CORE trace (like the XGATE simulator) when using BDM? I can watch the XGATE single step through memory in the dissasembly window, but the code is displayed as FFFF for every instruction. The source window doesn't ever highlight the current line. The memory window only shows FF for every byte in XGATE RAM. The BDM correctly triggers the XGATE breakpoints and the XGATE is single stepping correctly and executing the code correctly.
