Hi, right now I have codewarrior 5.9.0 and I want to use it to activate and use XGATE on S12XET MCU. does one know where I can find any info where I can find the help?
thanks,
Carl
Hello
I assume you are using CodeWarrior for HC12S V5.1. Am I right?
To retrieve that info:
- Start CodeWarrior
- Select Help -> About Freescale CodeWarrior
- Click on "Install Products"
- CodeWarrior version used is displayed on top in the Installed Products dialog.
If this is the case, just create a new project for HCS12XET using the wizard and make sure you
specify you want to create a Multicore project.
The generated project will include some sample code showing how to run portion of the application on XGATE.
CrasyCat
