Need Advise on desiding a micorcontroller
SureshF
Hi all,
I am new to this embedded technology but i know what i need very speicfically.
I need to Controlle the following things
1) 50 Digital I/0
2) 5 analog  temperature sensor, pressure monitor - Data recorded very mint for and should be stored at least last 5 hours of data.
3) USB and Serial communication - prefred USB
4) 2 - interrupts
5) single line LED marque display
Can any one advise what kind of processor and memory i can go with.
Should program in C or C++. My software user interface will be in vb.net mostly.
Thanks in advance,
Suresh
samiran_cj
If you are completely new to embedded technology, I can suggest you do not select a microcontroller but go for a full fledged tested Data Acquisition Card, which you can interface with PC. Since your  spec. are ready this will be easier.
