user-defined ISR and FIFO queues
Question asked by emilien on Jul 26, 2012
Latest reply on Jul 31, 2012 by Martin Kojtal
  I need some advice with my software design:
My ADCs are constantly feeding a buffer. Because I needed responsiveness, I don't use MQX interrupts and I installed user-defined interrupts instead. Some other task will read in the ADC buffer and apply filtering. This buffer is fixed size and I'm not sure if I will drop data that would cause overflow or if I will make the buffer circular.
In the end I think this is more or less a producer/consumer issue, with my ADCs interrupts being producers.
What kind of task synchronization tool would you choose? I could see that lightweight events are used to signal interrupts to tasks, but I think in my case lightweight semaphores would be appropriate, what do you think? I'm looking at the MQX examples but if you know a good way to achieve this it would be helpful : )
Emilien
