K40 CAN Bus: Help Setting Bit Rate
Question asked by Tom Kelly on Jul 25, 2012
Latest reply on Aug 2, 2012 by Butcher
Hi -
I'm using CW10.2 w/ProcExp to set-up CAN Bus communications between two processors.
I seem to be having trouble setting up the timing.  For example, the 'Bit rate' parameter under 'Timing' only allows two values - 5851.429 bit/s and 1497.9657143 kbit/s.  I wish to set the rate to 1Mbit/s.  When I try to set it to a value between the two 'ranges', Processer Expert produces the error "Timing setting failed - it is impossible to set the following items: initialization value".
Any ideas?
