MQX task manager
MQX task manager
Teckna
Contributor V
Is there a way to implement a task manager function in MQX 3.8?
Useful informations to show could be task execution time, memory use and so on...
Many thanks
Teckna
KJFPE
Its built into the IDE ie in IAR use the menu MQX -> Stack Usage etc
Teckna
Contributor V
My will is to report the application behaviour in field (runtime) not in developing process, sending the data on a serial channel (I use printf)
Many thanks
Teckna
c0170
Senior Contributor III
Hi Teckna,
have you read Getting Started with Runtime TAD Tool for Freescale MQX™ RTOS? I believe that's what you are looking for based on the description.
MartinK
Teckna
Contributor V
Hi MartinK,
I'm not able to find the document you talked about, nor in my PC nor in the Freescale internet site. Where can I find it?
Many Thanks
Teckna
c0170
Here's the path :
\doc\tools\cw\MQX_RuntimeTAD_getting_started.pdf"
MartinK
Teckna
Contributor V
Sorry, it comes with MQX 3.8.1, I was serching in the backed up 3.8 folder. Now I start to read it.
Many thanks
Teckna
Teckna
Contributor V
I've not read the document you point me to, I'll read and then I'll let you know.
Many thanks
Teckna
