Assembly code porting from GCC
embitel
Please let me know how to port the below GCC code to CodeWarrior (HCS12).
__asm__  __volatile__ ("tsta\n"
                              "bne ccnp_skip\n");
Thank you
Deepak
kef
Specialist I
__asm__  __volatile__ ("tsta\n"                               "bne ccnp_skip\n");
    You need to determine what was in A register in GCC code just above ^^ this line. Certainly A had to be loaded with some variable or maybe higher order byte of 16 or 32 bits variable. It could be also top most byte of some floating point variable and this asm line could be used to perform quick check for positive floating number is not to small or smth like that. Provided A was loaded with 8 bit variable var, code may look like this
a) in case ccnp_skip label is below __asm__ line
    if( var == 0 )
        // code between __asm__ and ccnp_skip label
ccnp_skip:
b) in case ccnp_skip label is above __asm__
   do{
   } while (var != 0);
kef
Specialist I
    if( var == 0 )
ccnp_skip:
   do{
   } while (var != 0);
embitel
Thanks Kef... It works...
CrasyCat
Specialist III
Hello
  Which compiler are you using here?
  CodeWarrior? Anything else?
  Also I assume you intend to embed assembly code inside of an ANSI C function. Am I right?
CrasyCat
embitel
Yes, you are right. I am using Codewarrior compiler and this code I want to embed in a C function.
Deepak
embitel
