Link Error : L1822
Link Error : L1822
spider_man
There is user made assembly function in my program, which I was using in different ".c" files and it was working fine .
But when I used it in a ".cpp" file I got a link error L1822 : Symbol functionname__FUc in file is undefined.
I tried everything to resolve it.
Included ansixbf.lib file.
Included the extern prototype of the function but its not working .
So if anybody knows about this link error plz help.
Thanks.
CrasyCat
Specialist III
Hello
Did you specify in the prototype of the assembly that it should use the C name mangling?
In order to do that the prototype should be enclosed between
#ifdef __cplusplus
extern "C" {
#endif
and
#ifdef __cplusplus
#endif
CrasyCat
CrasyCat
Specialist III
Hello
#ifdef __cplusplus
extern "C" {
#endif
and
#ifdef __cplusplus
#endif
CrasyCat
spider_man
It worked fine .
Thanks a lot.
Spidy :-P
