Ethernet question
Ethernet question
jambriz
If I'm using RTCS for sending socket, is activated CRC by default?
Thank you for your help
:smileywink:
PaoloRenzo
Contributor V
Yes! :smileyhappy: Ethernet outgoing packets will have CRC appended in hardware. For IP and other inner protocols, these are calculated by RTCS
PaoloRenzo
Contributor V
jambriz
Gracias Paolo!
:smileywink:
Thank you!
