What can I do to restore the configuration dialogue
changxiushanwu
Once I checked the "don't show this dialogue in future" so the dialogue disappeared.
But now I want to show this dialogue again  What can I do to restore the dialogue?
Tags (2)
pgo
Senior Contributor V
Dear Changxiushanwi,
Just try debugging without the BDM connected.
You should get an error dialogue with three options. One of these options being to "Change Settings".
This will open the missing dialogue.
Sorry - this is not obvious but I have no other way of doing this in the legay Codewarrior due to how low a level the dialogue operates at.
PS. You could also delete the settings file to restore the defaults %APPDATA%/usbdm/usbdm_HC12.cfg.
bye
BlackNight
the answer might depend on which dialog we are talking about.
Could you tell which dialog you mean?
BK
changxiushanwu
Ok,It's this dialogue
I just checked the "don't show this dialogue in future"
pgo
bye
changxiushanwu
Thank you very much.
This is a nice solution.
Thank you for your prompt reply.:smileyvery-happy:
