Kevin Smith
Stateviewer plugin on CodeWarrior 10.2 for ColdFire V1
Discussion created by Kevin Smith on Jun 13, 2012
Latest reply on Jun 13, 2012 by Erich Styger
I am trying to install and run the StateViewer eclipse plug-in with CodeWarrior 10.2 to debug FreeRTOS on a ColdFire MCF51CN128.  The plug-in installs correctly, but does not populate the Task or Queue data when running the debugger.  Instead, I simply see blank windows.  I am debugging with the P&E USB Multilink.  Has anyone succeeded in using this plugin with codewarrior?
