how to use interrupt of Freescale MC9S12G64
user_112139582
Hi everyone,
      I have a trouble  when programing the timer. here is the code. I'll very gratefull.
void SetBusCLK_16M(void)
 CPMUOSC_OSCE=1;                          //enable oscillator
CPMUCLKS_PLLSEL=0;                    //  disable   PLL
 CPMUREFDIV=0x41;    //Fref=Fosc/(1+1)=4M
 CPMUSYNR=0x03;      //  Fvco=2*Fref*(1+3)=32M
 CPMUPOSTDIV=0x00;     //   Fpll=Fvco/0+1  =32M,Fbus=16M
  _asm(nop);
  _asm(nop);
  _asm(nop);
  _asm(nop);
  while(CPMUFLG_LOCK == 0);
  while(CPMUCLKS_PLLSEL==0);
  CPMUPROT=0x00;
void initialize_ect(void)
  TSCR1_TFFCA = 1;
  TSCR1_TEN = 1;
  TIOS  = 0xFF;
   TCTL4 = 0x00;
  TIE   = 0x01;     //enable channel  0 interrupt
TSCR2 = 0x87;
  TFLG1 = 0xff;
  TFLG2 = 0xff;    }
  #pragma CODE_SEG __NEAR_SEG NON_BANKED
void  interrupt 16_Vtimovf (void)  //   this interrupt enty is ok
  if(TFLG2_TOF ==1)
           temp=TCNT;
    dd = ~dd;     //for LED sparking per second
#pragma CODE_SEG DEFAULT
void interrupt 8_Vtimch0 (void)//  This interrupt entry is wrong. WHY?
  TFLG1_C0F = 1;
  TC0 = TCNT +125;
     ZZ=~ZZ;    //for out put a wave at one I/O.
